crossman
- Southeast Texas
Re: More Transformer Loading
Rattus and Al are correct based on my lab data.
Rattus, I also succumbed to the "transformer flipped" fact.... and the first go round on the lab hook-up, I missed this on the wiring connections and wasn't gettng hardly any secondary current! I had the windings backward and voltages were "sort of opposite" of each other... then it dawned on me. In a wye, the same ends are connected together at the centerpoint.
Now that I understand this, the whole thing is rather obvious. Good job guys, y'all taught me something AGAIN!
Okay:
Experiment done with smaller loads than in this thread.
3 single phase transformers connnected delta on primary, connected wye on secondary, but only loaded across two phases as in the diagram in the second post of this thread.
Secondary current = .2 amps
secondary current was in phase with the 208 volts from line to line
secondary current was 30 degrees out of phase with the 120 v winding voltage
primary currents were:
Line 1 = .2
Line 2 = .2
Line 3 = .4
Primary current in Line 1 was 30 degrees out of phase with voltage of primary winding C
Okay:
Line 1 = .2
Line 2 = .2
Line 3 = .4
