electrofelon
- Cherry Valley NY, Seattle, WA
Do you also enjoy watching already dried paint?
Maybe....Lots of people visit the louvre and the MET
I'm assuming you are talking about the regulator?How does that work?
Without getting too technical, it basically just monitors the voltage trend, once a downward trend is started a motor starts to change steps ( often in 100 v increments) to maintain voltage. It can either remain there indefinitely or only a certain amount of time. When an upward trend starts, it will revert back to its starting position and remain there for a certain amount of time, before making anymore corrections. This is done to prevent "searching " through the steps.
Sent from my VS987 using Tapatalk
So basically a transformer with a bunch of taps that are changed by an actuator?
while 3 and 5 appear to be 2 winding isolation with a secondary 5kv and below.
What tells you its below 5kv?
At 7kv and above the are almost always top mounted.
Cool, I'll keep an eye out for that. Makes sense lots of 4800 around here.
But keep in mind the dual voltage cans. They have top mounted bushings but are often plenty of the 4800 volt systems. When time come they just flip the switch and the line is at 12470.
Yeah that's what my serving transformer is. I just got hooked up in September and the way the utility does it here is a separate truck comes by a few days before the line crew and drops off the transformer and other parts. So, I got to take a a good look at. They gave me a 25kva which is cool, many residences get 10's. It had a selector switch for 3 or 4 different primary voltages. I assumed that was for convenience of inventory purposes, but I guess it makes sense for planning for easier line upgrades later too.
FWIW, around here when POCOs have to deal with a new build a sub division in a 4800 volt delta area they will use 25kv rated cable and pad-mounts and set a jumbo pig at the riser and step up the voltage. A few years latter the line is upgraded to 25kv and the jumbo is simply bypassed.
