hardworkingstiff
- Wilmington, NC
Lets assume load 1 is 120-volts, 14-amps and load 2 is 120-volts, 7-amps and both are fed from a #12 wire MWBC originating in your home panel and the length of wire is 100' for each load (leave the panel, go 100' of wire to a JB, then connect the 2 loads. (For ease of calculation, ignore conductor length from the JB to the load.)
Questions:
What is the VD to load 2 if it is the only load turned on?
What is the VD to loads 1 & 2 if both are turned on?
Questions:
Assume a 120/240-volt service
What is the VD to load 1 if it is the only load turned on?What is the VD to load 2 if it is the only load turned on?
Assume the infamous 208/120-volt single-phase service.
