I have a client that wants to run some single phase 1/2 HP sump pumps from the normal power and with an backup generator. The normal power is 120/208 and these motors run at 208 volts. They want to use a single phase 120/240 volt generator for the back-up power. The motors would then run at 208 volts for the normal power and at 240 for the back-up. The motors are probably 115/230 volt but I don't know for sure. If they are 230 volt motors I don't see a problem since either voltage is within the tolerance for the motor (assuming these are typical motors). Does anyone see a problem?
