Given: A 25hp, 208 volts,60 hz,3 phase continuous duty compressor motor. rated fla 74.
When running, steady readings are;
a-phase 72 amps, b-phase 69 amps, c-phase 60 amps.Supply voltage is stable with little fluxuation.
Any input, anyone regarding the wide range in phase loads ampere readings.
Thanks in advance.
Thanks in advance.
