Alwayslearningelec
- NJ
- Estimator
Is this a real thing, guess actually called phase rotation, that the electrician needs to do regarding motors? Is it a long process?
The bump is literally one second. If the rotation is backwards then you would need to swap two leads. This can be a lengthy process depending on what's involved to make the swap. Typically it doesn't take very long.Is this a real thing, guess actually called phase rotation, that the electrician needs to do regarding motors? Is it a long process?
