Davebones
- North Of Tampa Fl
Have one of our test stands the 150 hp main contactor occasionally will drop out when we start the sump pump on the stand . This is a small 1/4 pump 120 volt . After going thru the stand the only thing I can see is a voltage drop when this pump starts might be causing this . I found this ( PQSI Model 1002-120V-CE ) relay online which they claim will prevent this from dropping out until the voltage falls below 30 vac . Wondered if anyone has used this product before ???
