- Illinois
- retired electrician
The only thing that has changed with the exception is the limitations on its use. Here is how it read in the 99 code....
I do not remember that, what code cycle allowed that?
The substantiation may prove very interesting and on point in this thread.
The exception was changed for the 2002 code to substantially what is it in the 2011 code. The real change is the limits as to where the exception could be used. In the 99 and earlier code it could be used anywhere.A disconnecting means, in addition to the controller disconnect as required in accordance with Section 430-102(a), shall not be required for the motor where the disconnecting means for the controller is individually capable of being locked in the open position.
