bestagents99
I am a member of a forum that involves converting buses to motor homes. Thia question regarging wiring has come up:
Do you ground the bus chassis to the green/ground at the panel on the bus?
Also, is sold core or multi strand the best wire for the wiring in the bus?
When running an onboard generator or inverter, the bus is not grounded at all. Should it be?
In Question 1, the ground and neutral ARE NOT bonded/attached at the panel (shore power supplies ground), but with a generator or inverter, does this still apply?
Should any or all outlets on the bus be GFCI/ACFI?
Thanks for any and all input on this!
