jahilliard
...."This is also why it is not a good idea to let a pump run with a discharge valve closed. The energy that goes into the water to produce pressure also produces heat and since there is no flow the heat cannot be dissipated, the end result can be a very hot pump indeed."
I just did some reading on "head" and pressure to better understand what you're refering to. This seems to explain it pretty well I believe...sound accurate Sahib?
