tim89s
- Brush Prairie WA
Let's say you have a 120 volt 60 watt light bulb and apply 60 volts to it. The bulb will glow dim due to ohms law V=A*R, right? Take the same light bulb and put 240 volts to it. The light bulb will go poof. Again due to Ohm's law.
Now lets say you take a 120 volt motor, lets say a skil saw, and apply 60 volts to it. Eventually the motor will burn up. But it is not due to Ohm's law, is it? My guess is the saw is still trying to generate the same wattage, therefore, when volts go down the amperage will go up. But, not lets put 240 volt across the same motor. The motor again will burn up. If the motor is trying to generate the same wattage and the voltage goes up shouldn't the amperage go down causing less of a draw? I realize I am not considering impedance into the situation. If someone could explain this I would greatly appreciate it
Thank you
Tim
Thank you
Tim
