GeorgeB
ElectroHydraulics engineer (retired)
 - Greenville SC
 - Retired
it's common to put the full load speed on the nameplate ... 10 RPM slip is pretty good. So we'd be looking at multiples of 0.89 to 0.90 kCPM ... I don't know the accuracy of the markers, but the 13.89, if a little off, COULD be a 15x or 16x motor speed. That conceivably could be a ball or roller bearing. Does this motor have plain or antifriction bearings?Thanks. This motor's is 890RPM. (which is kinda odd, I would assume it's a 8-pole machine, then rpm 900). I will have to verify when exact and at where this vibration was taken.
You misread ... I said I've **NOT** done enough to ...You said you've done enough to know what the lamination vibration characteristics would be, so could you share some light on that?
sorry.
