430-32A1 says overload protection shall be no more than 115-125% of name plate. 430-32c gives an exception to go a little higher.
The inside of my starter says to use name plate value and chart on cover. Where would you start. This is not a motor that I want to have problems with so I am going to go the 125% larger from the start to avoid a late night call back. Is this the best way to go about it or should I start from the exact name plate and see what happens?
Thanks
Thanks
