Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
I was wandering why when I wired 3 rock crusher motors rated at 120/240v at first 120 volts (parallel) the rocks became stuck in machine and seized it due to lack of power torque.
However, when I wired them at 240 volts the torque power appeared to increase enough to fully crush the rocks and stop motor lock up.
Since using a higher voltage yields lower current, while wiring to lower voltage yields to higher motor current draw but both yield the same/ similar power or watts, then how can it make a difference in power output? With WATTS being the same in either situation? Thanks
