srinivasan
 - Bangalore,India
Vendor recommended 132kw motor for fan having following datas,
operating medium: gas
flow rate:22000 Nm3/hr
pressure : 1200 mmWC. (normal operation is 800 mm WC at 50% speed operation using VFD)
Full load speed:2975 rpm
full load torque: 353 Nm at 1.2kg/m2
GD^2 value =59.6kg.m2.
I used the below formula for calculating motor sizing but i have not done before this like calculation.
Power rating=(T*N)/5250 where T is in Lb ft and Speed is in RPM. Please give correct rating of the motor for above data
