Bob Kraemer
- Ohio
Is there is quick simple way to calculate the starting current of an electric motor?
Here is an example from a book.
Here is another example which has been calculated by someone in other forum. I am not sure regarding this. It is as below
I have a 90 kW 380V 50 Hz induction motor directly coupled with a refrigeration compressor. Starter is star/delta and full load current is 160A. I found the following data on the motor data sheet.
I need others comment regarding this calculation.
IA/IN = 7.5
MA/MN = 2.4
MK/MN = 3
Mass moment of inertia = 0.52 kgm2
