We have motors that are drawing uneven currents.Parallel feeds from soft start motor starters. The problem is that I cant figure out why each leg draws different current readings.They are 480 volt 3 phase 100hp induction motors that drive a gear box the current is on# 1 of the parallel wires A phase is 89amps the #2 wire A phase is 100 amps B phase #1 wire is 98amps #2 wire B phase is 110amps and C phase #1 wire is 110 #2 wire is 90 amps . I know the wire size is the same,length material,cir mill area,terminated in the same maner as per code. Why would the current be different.By the way the voltage is a-b 489v b-c 494v a-c 491v any info would greaty be appreaciated. I am thinking about the voltage relation to current
