SceneryDriver
- NJ
- Electrical and Automation Designer
I've recently moved from the West Coast to the East, and I've just heard a new (to me) case of what I think is an inspector going overboard.
Is it a common practice on the East Coast for inspectors to require that breaker panels and conduit run in basements (considered a dry location) to be mounted on plywood, or otherwise be stood off from the cinder block/concrete wall? This is a residential application.
I can find no justification for this; I've run many hundreds of feet of EMT directly attached to brick and poured concrete walls and ceilings without problem or comment.
I've mounted many a breaker panel directly to the basement wall without standing it off. Have we all been doing it wrong all these years, or has this local inspector gone off the deep end? I'm hearing this secondhand, but the inspector is apparently claiming that it protects against some type of corrosion of the conduit. Consider me skeptical to say the least.
Thanks, all!
SceneryDriver
Thanks, all!
SceneryDriver
