First off, I am not an inspector... :blink:Say there is a UL listed Type 3R/12 enclosure.
The installer used a reciprocating saw to field cut an opening.
A 2" NEMA 4X "Meyers Hub", found on the installer's shop, is installed into the field cut opening.
Rigid aluminum conduit is installed into the Hub.
What is the UL Type rating of this installation? Would it be acceptable to you as an inspector? What tools or guidelines would you use in your evaluation?
I'd say NEMA 3R or 12, depending on indoor or outdoor installation... at best, which is based on the lowest protection level provided by the assembly (Table 110.28 as one resource). So what does UL listing have to do with it?
The reciprocating saw threw up a big flag based on my field experience, but the thought was using a "sawzall", and then remembered a jigsaw is also a reciprocating saw. Neither would be my first choice, sawzall totally out of the picture (at least with standard blades), while a jigsaw I'd resort to if the only option available... and likely would require a deburring tool. As an inspector, I'd only be able to make a determination on the hole if there were visible voids in the sealing area... and it's hard to say if I'd really be that scrutinizing at the time.
I can't tell whether the rigid aluminum conduit is a loaded question regarding dissimilar metals, but I happen to know 4X hubs come in zinc, aluminum, or stainless steel.
So what's the point in you asking a question to reply to a question?
