Where do you mount the din rail? in a pullbox?
Yes. You could bolt that socket directly to the back of an enclosure. But... if you have 2 or more devices, it's easier to mount a short piece of DIN rail (only 2 bolts), then you can mount and slide however many device you want on that length of rail.Where do you mount the din rail? in a pullbox?
Thank you. Are there any pre-built din rail box that is commonly used? Also Is there anything in the code about mounting relays I should look out for?Yes. You could bolt that socket directly to the back of an enclosure. But... if you have 2 or more devices, it's easier to mount a short piece of DIN rail (only 2 bolts), then you can mount and slide however many device you want on that length of rail.
Where can I get this box? It looks niceHere is a quick pic of something I fabbed up for a prototype last year. You can see (2) lengths of DIN rail fastened to the back of the enclosure that allow all kinds of devices to be mounted. This box is maybe way more serious (big / heavy / weatherproof / hinged door) than you need - but you get the idea.
As far as NEC code goes, I will leave that to real electricians to answer. I am just an engineer, though I did know a Holiday Inn joke once.
This might be a stupid question, but do the boxes have to be UL listed to put UL products in there?But you don't have to use one with a hinged door. Here's one I put together for some contractorsView attachment 2560275
Not a stupid question at all, and one I can't answer. I know some things require listing and some things don't.This might be a stupid question, but do the boxes have to be UL listed to put UL products in there?
Are you planning to put a UL label on your final assembled panel?This might be a stupid question, but do the boxes have to be UL listed to put UL products in there?
Only if the assembly as a whole is to be UL listed and to do that you need UL to bless your company so you can put UL labels on the assemblies.This might be a stupid question, but do the boxes have to be UL listed to put UL products in there?
Wouldn't that be necessary only if he was looking to sell them?Only if the assembly as a whole is to be UL listed and to do that you need UL to bless your company so you can put UL labels on the assemblies.
It is still an industrial control panel whether he is selling them or not. if ICPs are required to be listed in his jurisdiction than it would need to be listed, although like a lot of things, it would likely sneak past since he probably is not going to have this permitted and inspected anyway.Wouldn't that be necessary only if he was looking to sell them?
article 409 does not call it out because it is called out in article 100.Your friendly neighborhood electrical distributor will likely have access to a line of electrical enclosures, you must pick one that is suitable for your environment (indoor, outdoor, hose-down etc.) and that suitability is covered by it's UL listing, so that's a good rule for picking one. Most distributors also have a line of DIN rail available too. Whomever you would be buying that Eaton alternator from should have the other parts you need for this.
Some states have rules stating the number of devices in an assembly as a trigger point for when an overall NRTL listing is required; Washington State was 5 devices (including the box) when I lived there, I think that California is 3, etc. etc. I have no idea about NY, but I have heard that in general, NYC is pretty stringent on things like that. But the NEC Article 409 does not specifically call it out, so an AHJ can interpret the need as they see fit. If you are not going to get it inspected, then the AHJ issue is moot. But the other aspect is whether your insurance carrier has a requirement that all electrical equipment be NRTL listed. Many do, so if you ignore it and the device or equipment causes a fire, they might use that to get out of having to pay for the damages.
Might I suggest though that you hire an electrician? There may be more to this that we cannot help you with because we are not there with eyes on the total situation.
