T-Stripes
- Chimacum,WA, Jefferson
Residential backyard. I have drilled and tapped the 1/8" steel plate (spot welded to the post(s) intermittently) and bolted the panel to the fence. There will be ground rods along the fence line. Do I need to run the EGC through a 2" grounding clamp on the nearest steel fence post, or is the bolted panel installation enough of a bond for the fence?
The rows of woven 6" plate steel are not welded at every post.
