macmikeman
- Planet macmikeman
1. + 2. I have had a few either go out on me or start pulsing. I go back to job and it was quite easy to pull out the bad light and driver and replace them for the conditions (but it was a go back so there's that.) My supplier replaces at no cost for a year. After I year from installation completion I charge for go backs .Just letting everyone knowI am moving away from can killerz led wafer lights for a number of reasons and will be recommending traditional housing with LED bulbs. Here is why:
1. I have had some issues with buzzing and noise from the wafer lights, and these are obviously a nightmare to change if you have such a problem. I had two projects with a ton of these and I noticed the noise, and I was terrified the client would want them replaced, but fortunately they didn't notice.
2. Clearly they are more difficult to change than just a bulb if / when they go bad, and of course finding identical replacements down the road may be difficult.
3. You essentially have to lay these out twice, once when you get the wires in place and then again when you cut them in.
4. It's stressful to keep track of the wires and find them and cut your holes in the right spot just kind of a hassle all around.
5. I don't want to cut the holes in the drywall, it's miserable and makes a mess.
I understand they make ther rough in pans that would solve problems 3 4 and 5,. So if the customer insisted on these, I would probably insist on stalling the rough-in pans.
This will be the new East West electric policy, please make a note of it, and tell all of your friends![]()
3. I lay out once, make cross hair mark on floor with sharpie, send down a drywall screw into plywood floor , or a tap con into concrete floors, or in worst case, blue tape and mark tile, carpet, sheet vinyl flooring in existing dwelling remodel jobs. Come back after sheet rock and paint and laser up to the ceiling for the cut in of the light opening. Be a nice guy and remove the screw or blue tape on the floor afterwards.
4. My stress relief for dealing with the cable or cables for the driver is to use my Dewalt Cable stapler, and secure the one or two cables perpendicular to the side of the bottom cord of the nearest truss or joist right at the tail end of the cables during rough in , leaving a long enough loop of cable above the staple shot in to be able to pull the cables up and out of the staple ( if you have ever used the Dewalt gun you know that is quite easily done with no strain) to retrieve them from the staple, and pull them out thru the hole to attach driver. Credit where it is due- it was my son who came up with that method for me one day when he was assisting me rough in a house.
5. I agree , no argument there. Charge appropriately. I have yet to use one of the rough in pans .
