johnnyvuus
New member
I just want to know how to select the primary and secondary of the 3 phase transfomer being Delta or wye?
			No argument there, but a transformer with a wye primary should have the neutral point left floating. Don't bond it or connect it to the source neutral or anything else.jtester said:Wye connections on the high side are common in higher voltages, 25 kv and 34.5 kv for example, they are less expensive, and a little more forgiving when subjected to high voltages. Wye connections are also more common in underground high voltage systems because they aren't susceptable to ferroresonance.
LarryFine said:No argument there, but a transformer with a wye primary should have the neutral point left floating. Don't bond it or connect it to the source neutral or anything else.
