Is it acceptable to place a plastic mud ring on a 4x4 square metal box? Or does it have to be a metal mud ring? How do you ground the ring if its metal? Tek screw and loop the ground? Or do you get the ground thru the mud ring ears and screws?
All modern 4x4 boxes have 10/32 hole for a ground screw. Don't really understand your question.
You cannot ground a plastic ring its plastic but you knew that. :?
There is no provisions for a ground screw on the metal plaster ring itself, so , dont jack it up by putting a self tapper through it and running a jumper to the box.
Generally the bond between the ring and the box is made when you place it on the box and secure it with the (2) 8/32's that are provided with the box.
I dont know of anything that wouldnt permit a plastic mudring on a metal box although I've never felt the need or the desire to use one.
JAP>
