I need a ohm meter capable of reading resistance that is found amongst fire alarm panels. one of our line voltage guys was spouting off about how is meter was the best. It was a fluke. Turns out that line voltage meters don't read resistance high enough. Any suggestions on a meter that works at higher ohms?
Sent from my SM-N910T using Tapatalk
Wow, talk about a thread getting off topic...
To answer your question, your options are wide open
. In the old days, we had voltage testers, most often a "Wiggy" that we carried in our pouches at all times to check for voltage. Mostly because they were not bulky. When you needed to troubleshoot, or check small DC voltages etc. You went and got your Triplett shown, or a Simpson, 260, if you were serious, or some half butt Radio Shack multimeter if you were on a budget. Then came, proximity "pen" testers, and a couple companies also started creating voltage testers that had both proximity sensing and/or continuity along with the voltage testing. Throw in also that in this same time frame, meters, both voltage and continuity were evolving, (or devolving if you wish) from analog (meter needle display) to digital. Nowadays it is common for a field electrician to carry a compact meter that that displays accurate voltage, amperage and resistance, but the versatility of each is limited to the desires of the person.
So, you can get a single meter to do a bunch of things or you can get different meters to do different things. If all you are looking for is a meter to read end of the line resistors, open, short, and ground fault, you can pick up a 10 dollar analog meter at Harbor Freight or Home Depot. I would not use the same on a live circuit, even though they have that function! But it will serve just fine for resistance troubleshooting.
I have a Fluke 117 that is digital and has the functions you are looking for, but I wouldn't carry it on day to day electrician stuff. I love my old Simpson 260 when I am trouble shooting real industrial style voltage. I would prefer my Fluke when I am doing newer PLC type troubleshooting. And then I always have to consider, CT's and how I am going to read both DC and AC current.
Bottom line, don't necessarily try to get one size fits all. There wouldn't be thousands of options out there for various combinations of electrical testing features if the demand wasn't there.
