Exmark
- St. Louis, MO
Hi everyone,
I am a long time reader of this forum, and I am excited to make my first post. Thank you in advance for any insight you can give me
Today I ran into a situation that I do not know the answer to 100% and my efforts to find the answer (with absolute certainty) were in vain! I know this is the right place to find the answer, hence my first post.
We are under the 2008 code cycle. This pertains to an individual dwelling unit. The circuits in question are feeding pool equipment (pump, service outlet, and lighting). The dwelling unit has a 120v/240v single phase service. If I missed any relevant background information let me know, its been a fairly long day.
Can a 2 pole 20 amp GFCI breaker feed a 230v pool pump 1.5 HP, a 120v lighting load (small load, don't know specifics off-hand), and a service outlet using a Multi-wire branch circuit (2 hots, neutral, and ground)? This is the part I keep going back and forth on. Can a multi-wire branch circuit feed 120v and 240v loads at the same time according to the NEC? My gut tells me no, but I can't find a specific reason. Please settle my mind so that I can sleep!
I have not visited the jobsite yet, so lets make a few assumptions. 12-3 NM running inside the building, changed over to THHN/THWN before leaving the building. Lets assume proper bonding and pipework outside the building also, just to keep things on subject.
Thank you again in advance!
Exmark
Exmark
