Branch Circuit, Multiwire. A branch circuit that consists of two or more ungrounded conductors that have a voltage between them, and a grounded conductor that has equal voltage between it and each ungrounded conductor of the circuit and that is connected to the neutral or grounded conductor of the system.
so just use a three pole breaker
and would you have to mark all three circuits on that neutral wire
I have a gym space. I want to connect lighting at 277volts, single phase - 3 circuits with one neutral ( i.e. 3 hot and a neutral) in 3/4" conduit. Is this considered a MWBC - multi wire branch circuit? Will NEC 2008 - 210.4(B) apply here? Thanks.
in the panel board it should be marked
