Don,
I probably extended myself a bit when I implied that tools are used by some to impress and referred to them as being mystical.
I doubt if there are any of us who purchase tools with the intent of impressing others.
But, with all practicality even though I have this Super duper Cat III Fuke 26 with a number of bells and whistles where in most cases a wiggy would work just fine when checking for power and a wiggy is a lot less expensive.
But, I must admit one has arrived when you have your very own person high quality DMM. Is the need for a DMM driven by seeing that others have them and that?s a weapon that you should put in your holster? Maybe so. But hopefully it is because of the need for accuracy, the extremely high impedance ohms/volt sensitivity, and the ability actually measure resistance and current.
1) Does one need the ohms/volt sensitivity? Is it need by the electrician.
2) How often do you need to know the exact resistance when all that you are checking for is continuity. A DMM is an expensive way to do it. When was the last time you had to know what the exact resistance was?
3) Then the ammeter. Without a clamp on ammeter accessory most DMMs are not able to measure over 10a anyway.
A lot of this depends upon what type of work is being done. Often times DMMs are a necessity when troubleshooting.
Even though it has never been my intent to "impress" clients with this fancy DMM one has to admit that they do look a heck of a lot more impressive than the lowly wiggy and we feel a bit more high tech in using it.
But I will be the first one to admit that I just like my toys.
Dave
Dave
