allenwayne said:Trevor the question is not about nipples but cable clamps.Be it integral nm clamps or ko clamps.What are they listed as far as capacity goes.I would have to say that if the listing has been tested for one nm cable under each clamp,then to place 2 cable assys. under that same clamp would be a violation of the listing.Since they have only been tested with that one cable under the clamping device.To say if they are strong enough for one then they will be ok for two is a silly argument.Why stop at 2 why not 3 or 4 or 5 if the fit.
Just because there are 4 openings in a 1 gang NM box doesn`t mean that you can put 4 12/2`s and a device in that box.
I disagree with several of your points.
"I would have to say that if the listing has been tested for one nm cable under each clamp,then to place 2 cable assys. under that same clamp would be a violation of the listing."
Using a device in a way that it has not been tested is not a violation. . Lack of testing could be cited by the AHJ as a reason for not accepting it but that doesn't mean that it's a violation of the code. . It's not a violation.
"Since they have only been tested with that one cable under the clamping device.To say if they are strong enough for one then they will be ok for two is a silly argument."
It may be an argument that you wouldn't accept as the AHJ, but it's not a silly argument. . It's a logical argument. . A Romex connector actually has some squeezing pressure to hold whatever is passed thru it. . What kind of holding ability does the nonmetallic box tab have to hold ?Multiple cable entries? ?in a single cable knockout opening? [314.17(C)X] ? . Sometimes the box tab doesn?t even survive the insertion of a single Romex.
"To say if they are strong enough for one then they will be ok for two is a silly argument.Why stop at 2 why not 3 or 4 or 5 if the fit."
Why stop at two ? . That?s what the manufacturers have asked. . That's why they don't stop at 2. . Did you look at the link that Allen posted ?
http://www.aifittings.com/c_19.htm
"Just because there are 4 openings in a 1 gang NM box doesn`t mean that you can put 4 12/2`s and a device in that box."
That depends on the sq" capacity of the box. . But that's not what's being debated right now.
David
