Multiple Electrical Failures
ghostbuster
Failed Items:
1.Capacitors on capacitor start refrigeration motors-QTY 4
2.Electronic circuit boards
3.Lighting ballasts
Walk-in restaraunt meat coolers failed during the night,all the meat had to be thrown out.
FOUND
Water entering above ground outside PVC electrical boxes (6x6x4) (completely filled with water).Phase to phase and phase to ground flashovers were occurring.
QUESTION
The water has also filled the underground 1" pvc conduit(100') connected to these boxes.What is the best way to remove all this water??
Pierre C Belarge said:
Youser... what fun.
I would disconnect all power and send a compressor hose into the affected raceways. Then try to locate the reason for all of the water.
Good luck!!!
Wouldn't the AIR just blow over the top of the water in the pipe? I personally would use a shop-vac to suck the water out...
