frostyra
- North Carolina
I work for a radio station with a standby 250KVA diesel generator. We are preparing to install ANOTHER similar generator as safety backup. The generators will be in separate, adjacent rooms in the transmitter building. I have had little luck in finding answers to these two questions in the NEC:
1) MUST the disconnect breaker for the newer generator be within sight of the generator, or may it be in the existing panel next to the older generator in the next room?
2) MUST the two breakers be mechanically interconnected so that it is impossible to have both breakers on at the same time? Switching between the two would only be done by trained and authorized engineering personnel.
I'd appreciate any help on this subject; if you can reference code sections as well, I'd appreciate that also.
Thanks.
Thanks.
