Shaneyj
- Katy, Texas
- Project Engineer
I am looking at a design that calls for a redundant 100 HP motor to back up the primary 100 HP motor.
I would like to use just one starter with an interlock that manually controls which motor is being energized. The problem I see is the switch would have to carry the load of the motor - unless some type of relay contact was used (at rated i and v).
Somebody has probably done this before. Do you know of a device that allows what I am looking for?
