gar
- Ann Arbor, Michigan
- EE
221024-2124 EDT
TwoBlocked:
If you are still watching this thread, then my question to you is how you would study ( calculate ) the voltage across a load resistor at the end of several transformers cascaded in series?
By cascaded in series I mean the following ---
1. Each transformer consists one single primary two terminal winding magnetically coupled to a single two terminal secondary winding with high resistance isolation between the two windings.
2. We assume that each transformer can be approximated by an ideal transformer with an internal impedance of some series resistance, and some series inductance.
3. By cascaded in series I mean the secondary of one transformer is connected to the primary of a next transformer, and so on.
So how would you calculate the change in voltage across the load resistor as resistance changes?
TwoBlocked:
