koelsche
New member
- Wilmington de
Have an installation of five motors in one embedded PVC conduit. 5hp each. All are on AB Drives. They run fine until run at low HZ around 4hz then trip out on over voltage load side. Run with single THHN conductors with filters on load side. No problems if drop carrier frequency to 2kHZ but motor noise is too much. The noise is especially bad on higher rpm motors. Can I adjust carrier freq. on the just the slow run mtrs or do I need to tune all the same? I know install is not ideal but a lot of cash to change so trying to make it work.
