In a three phase panelboard, do you need a three phase breaker if you share a common neutral with all three phases?
conductors need to be grouped together in panel also
Three basic questions in a row from the same person that looks like homework ? Where are these questions coming from at of the blue?
If in a shared pipeline with other circuts, multiwire branch circuts need to be grouped (tie wrapped with nuetral)when they enter panel
What is your Code reference?
I knew it was new for 2008 I just could not find it.210.4(D) this is new to the 2008 NEC.
Chris
Thanks.
If in a shared pipeline with other circuits, multiwire branch circuits need to be grouped (tie wrapped with neutral)when they enter panel
Depends on the code cycle that you're under. 2008 the answer is yes or a handle tie.
Do they make a handle tie approved for 3 breakers? I've heard that there isn't any approved for that just yet. One of the manufacturers is suppose to have an approved one sometime in 2009.
SQ D does, I'm not sure about others.
Roger
It's also a YES if the neutral-sharing conductors supply the same load.I'll go out on a limb and say NO, BUT you would need a handle-tie covering all three breakers or handles.
