dwellselectric
Inactive, Email Never Verified
- Cape Cod, Massachusetts
So im not used to using this brand of panel. I like QO. But this was less expensive. So when I removed the cover I noticed there was a neutral bar on both sides and an insulated bar connecting them. And under the neutral there was a ground bar. So the neutral bar had a jumper to bond the panel. Question is if I has to use that ground bar for neutrals as well would I be required to install a jumper between the ground and neutral bar or does that factory jumper take care of thatt? Im going to install a jumper anyways I was just curious. Thanks for the input ahead of time
