mgelectric
- Sacramento, CA
not required.
roger said:Well, I don't know about everyone else, but when we go into a residence to perform service work we go ahead and put GFCI protection on all the 15 and 20 amp 125 volt circuits so if we have to plug a drill motor or other tool in any receptacle in the house, we're covered.
We use breakers so we have a larger material mark up.
What would normally be a simple 1 hr service call ends up costing these customers a few grand but we are safe, code compliant, and happy, life is good. :grin:
Roger
mpd said:the heat tape on condensate piping requires GFI protection
celtic said:WOWZEE...
Wouldn't a plug in model of GFCI afford the same protection at quite a different price?
roger said:Absolutely, but that would be a ridiculous solution, not to mention less of a profit maker :wink:![]()
Roger
curious george said:We do not get to pick and choose which code rules we want to follow. I recall reading a thread about a laundry circuit being able to have receptacles all over the house and the only violation comes from someone plugging into it, not the installer who placed all the receptacles on the laundry circuit.
Roger, correct me if I am wrong, but I seem to recall you agreeing with that logic, because of the literal wording of the code rule.
iwire said:Roger, you simply sell the customer the GFCI cord at a greatly marked up price. :grin:
mgelectric said:I was thinking this was just a furnace outlets. Not sure what he is refering to.? If it's the furnace then NO.
iwire said:.......BTW, good to see you back, I had not seen you post in a while.
Roger
celtic said:Not that I am calling you a liar ....I just don't believe you![]()
celtic said:Aren't they requiring "whatever you are plugging in requires a GFI" to come with it's on intergral GFI protection? (Blow dryers, vending machines, etc)
Better be some strong ceiling joist!480sparky said:Could it be that one of these have been installed in the attic? :grin:
