LISHAJI
- Albany, NY
I have a 3ph 208/120V 225A Utility Supply for a Fish Hatchery Unit & a 30kW 3ph backup Generator for this supply. There is some spare capacity on this generator, which I want to use it as a backup for a 120V residential load. This residence is supplied by a seperate 1 ph 120/240V utility transformer. Now the Utility requires all neutrals to be bonded together. So if I where to bond the neutral of the 3ph-Utility, 1ph-Utility & 3ph-Generator, am I violating any CODE or producing any safety issues or multiple ground paths etc. The maximum distance between any two sources would be 200ft. The 3ph load are 3 ph motors balanced loads while the 1ph residential load may be little unbalanced on each leg. Your input would be much appreciated as to where I stand.
