kwired
Electron manager
- NE Nebraska
- EC
At one time I don't believe most AFCI were compatible with 208 volts and MWBC's. I don't know if that is still an issue or not, or which manufacturers it may or may not apply to.if it says on a afci or gfci 2 pole breaker 'to be used on 120/240V circuits' can I use it on 120/208V single phase circuits? in NYC we only have 120/208 single phase for residential.
GFCI protection only shouldn't have any problem with this though, all it is looking for is net zero on all protected conductors, what current goes out on one conductor has to return on any other protected conductor of the circuit. So as long as nothing finds a return path that is not through the GFCI it will hold.
