ivanaa
New User
- New York, USA
- Other
Hello all,
Just wanted to say this is a great forum with lots of good info.
I have a question regarding MWBC in a residential setting for an initial assessment and job planning.
Presently a Murray 8/16 circuit panel has 12 circuits installed, 4 standard sized single pole breakers and 4 tandem breakers but single pole breakers. It seems that there are at least 2-3 fewer neutrals than the 12 circuits - yet to fully trace everything - which means MWBs exist and even if they are split across phases, do not have tied breaker disconnections. Seems clearly a risk in both violating the NEC and for safety.
I am wondering if a MWBC can legally and safely be established with two tandem single poll breakers arranged such that one pole of one tandem breaker on leg A is adjacent to one pole of the other breaker on leg B with a handle tie between them. See the image for specific arrangement. Given the tandem breakers are already installed, we would like to re-use them. I believe this would meet code, even in NYC, and pass inspection. But wanted to get an opinion as I have not found clear guidance yet on Tandem breakers and MWBC other than the usual - have to have each leg on a separate phase to share the neutral.
Since we will be adding circuits, we will need to use more tandems or possible replace the panel.
Your input is appreciated.
