Hi Everyone, I have a electrical problem in my personal home. First I had a tv and 3 ceiling fans over heat and smell of burning in two bedrooms in my home. I checked all wiring and everything came back good. I did voltage tests under load and current tests and no issues. I also checked all the arc fault breakers and changed phases and put regular breaker on circuits and still no fix to problem. I was taking current readings with my amp probe and I shut my main off one day and checked the neutral and I had about 1 amp of current still with main shut off. So I went over to where the #6 bonds to the water pipe in the floor and still 1 amp of current with main shut off. I have a bonding screw in place in panel and ground rod is also installed. I had the power company out twice to check the under ground wire feed and no issues there. Still have current to ground at water pipe all the time. I went into 5 of my neighbors houses and they all have the current to ground at water main also. Some of them are experiencing power quality issues also. The Electrician that wired my house won't get involved to help so I have been dealing with this for a month and a half so far. The power company put recorders in my meter and transformer and after one week they told me everything looked ok and the current to ground was normal. I am lost at this point. Objectionable current? EMF? Please help with your suggestions Thanks!
