Alwayslearningelec
- NJ
- Estimator
You can under certain circumstances, for instance if the panel is the service and has the bonding jumper. It also depends on the code when it was installed. There are lots of "if's" involved. In residential settings with a single panel, it's more likely to be compliant; in commercial settings IMHO it's more likely non-compliant.someone said you can put a neutral and ground together on same bar.
good catch !There is a second neutral lug to the left of the existing neutral.
Which is meant for a GEC, but can be used for another, smaller, neutral.There is a second neutral lug to the left of the existing neutral.
