james durkin
They added this Article 411.4 B Pools spas fountains and similar locations. Lighting systems shall be installed no less than 3m (10ft) horizontally from the nearest edge of the water unless permitted by article 680. Article 680 22 C permits lighting to be installed 5 ft horizontally from the nearest edge of the water. I have always used the 5ft rule with low voltage lighting and have not had any inpection problems. Does anyone have a suggestion on this conflict of the code. It's pool season and I don't need the greif. Jim
