Looking at the 2014 article 210.8(D), I find it interesting that the title of that article speaks of the branch circuit, but the text says it is the outlet that requires GFCI. For all I know (and I have no interest in learning more :happyno: ), there are three continuous wires that start in the panel (located 3 feet from the DW, on the dining room side of the wall) and pass through an outlet box without terminating there (i.e., no wire nuts) and continue on to the point of connection at the bottom of the DW. One could ask where the outlet is in this installation. Current is not taken from the premises wiring system inside the outlet box; it just passes through that box. Where does the premises wiring system end? If it ends where the wires terminate under the DW, then clearly I can't install a GFCI device there. I don't think my breaker panel is a type that can accept GFCI breakers.
If I had to sell this argument to the AHJ, do you think it would work? :happyyes:
