I am designing branch circuits for a 208/120V double oven and a 120V warming drawer(installed below the double oven). The electrical requirements for the double oven are to be equipped with a 4-wire,#10 ground, fused separately, and a 40amp connection. The electrical requirements for the warming drawer are to be hard-wire direct separate 15 amp minimum 2-wire with ground. Based on NEC article 210.19(A)(3)Exception No. 1, would it be compliant to use a 50A/2P breaker, (3)#8 w/ (1)#10ground to feed the double oven and the warming drawer from the same circuits(2-pole) and tap the appropriate conductors to feed the other? The electrical requirements per manufacturer specs state that each appliance should be fed from separate circuits. Could someone help me to understand what to do in this situation?
Thanks,
David - St. Louis
Thanks,
David - St. Louis
