Hi all, I work as an assistant to a general contractor and am working to become an electrician one day and had some I had a few questions regarding the NEC code that I have been unable to find posts on and I was hoping you could help:
1) For kitchen / dining area outlets that are not on the counter, why should they be supplied by the SBCs? The only thing I could think of plugging into a wall outlet in the dining area is a vacuum and wouldn't you want the high-draw counter devices (microwave, toaster oven, etc.) not sharing the same voltage as another device?
2) Is there any order that you have to put the outlets for the SBCs in on the counter top? For example, can two outlets be fed by SBC1 and SBC2 respectively right next to each other on a 2ft section (in a two gang box) and then have another outlet on the opposite counter on either SBC1 or SBC2? Or do the the branch circuits have to be on both sides of the counter evenly?
Thanks!
Thanks!
