AWinston
- Murrieta, Ca
I have a client that is giving pushback on this code section for a custom home. In each habitable room, the architect provides a recessed light. When I told them they need lighting outlets controlled by a switch, they asked if the controlled can light can be considered a "switched receptacle" especially since inspectors never had issues in the past. I always design to exactly what the NEC states. Am I wrong? Does each habitable room need a switched outlet if there is permanent lighting in the rooms?
