I have a 2P-200A, 240V, 1 phase, circuit breaker type Automatic Transfer Switch fed from two sources: Source one is a 100KVA 480V-120/240V 1 phase transformer fed from utility. Source two fed from an 80KW 120/240V 1 phase diesel generator. The ATS feeds a 400A, 120/240V, 1 phase, Main Lugs Only panel board at downstream. The feeders running from the transformer through the ATS to the panel board are over 10 feet long.
Would the ATS circuit breakers meet the requirements for the over current protection device at the secondary side of the transformer per NEC 240.21.(C)?
Thanks,
Thanks,
