I don't know if this is the information Tom was talking about but it's pretty informative.
Thank you.I don't know if this is the information Tom was talking about but it's pretty informative.
Of course it's voodoo. If it wasn't, there would still be an ohm requirement when adding the second rod. Or third or fourth. The code basically says, "You have to get 25 ohms or less if you use one rod, but if you use two, don't worry about it."Not vodoo at all. Testing was done on ground rods to detetmime why 2, why 6 ft apart…I have info from AEMC I can post in a few dsys
Probably based on recommendations from ground-rod manufacturers.The code basically says, "You have to get 25 ohms or less if you use one rod, but if you use two, don't worry about it."
