Nec 314.17 B 4 box temp limitation
Jpflex
Electrician big leagues
Victorville
Electrician commercial and residential
It seems more proper if NEC said
Nonmetallic boxes and conduit bodies shall be suitable for the [LARGEST] temperature rated conductor entering the box or conduit body instead of "lowest"
Unless this has something to do with wiring having to be uniform within a conduit, such as same voltage or temperature rated insulation it would make more sense that a box can withstand the highest temperature it will be subject to rather than lowest?
